How to get started on a mac?
It’s holidays down here in Australia and I want to get my feet wet in the world of micro controllers while I have a ton of free time on my hands. Your tutorial series looks great and I’d love to follow it however the only computer I have access to is my mac laptop, so I don’t have a serial port to use.
What is your recommendation on how to get started using a mac with no serial port?
Time is no issue so if there is some hectic breadboard workaround I can setup that would be awesome
Thanks in advance
Use a USB to serial converter.
Also try
http://www.obdev.at/products/avrmacpack/index.html
I’ll second the above suggestion. I’ve been using one from Cables2Go for a couple of years now and I’ve yet to find a situation where it doesn’t work as reliably as a hardware com port.
Ion:
What? Since when!
I’m assuming you are a uni student then.
Yeah USB → serial cable or converter is the way to go. Get a name brand one rather than a $5 eBay special.
hi all
Is it OK to use Breakout Board for FT232RL USB to Serial?
http://www.sparkfun.com/commerce/produc … cts_id=718
I’m a beginner and about to buy the kits for programming.
I think so. Double check that you can find an FTDI serial driver for your machine.
I have one of those boards and I have a Mac, I should see if they work together… if I find time to check that out, I’ll post here.
Sure, FTDI USB chips work on OSX, Linux and Windows
inventore123:
thank inventore123 and wiml. My USB to Serial arrived this morning.
Will pair it now with my mac.
