How to power 3 relays?
Hi. I am currently working out the electronics side of an automated drinks dispenser. It utilises 3x 12V air pumps which I intended to power using relays. However I am very new to this and am not sure the best way to go about supplying power to 3 separate relays. Is there a convenient way to supply the power to all 3 relays (and the arduino itself if at all possible) without having 4 power sources?
To clarify, all of the 12V outputs need to be individually controllable so couldn’t run from a single relay (unless there’s a way I’m missing).
Apologies if this is a dumb question.
You might be looking for something like 3x these https://www.sparkfun.com/products/13815
Be sure to run through the hookup guide here https://learn.sparkfun.com/tutorials/be … 1615791300 which will assist you in their use :slight_smile:
