HX711 Rate Change Turning Power OFF
Hello! I am using an arduino giga to power a nextion device, a stepper motor and the HX711 board connected to a s-type load cell. I have everything running correctly. Except the sampling rate is near 10SPS. I see that pin 15 has a way to be able to increase the sampling rate. When I connect it to a shared power source, I lose power to everything and nothing will work.
You open the solder jumper so that the RATE pin is pulled up to VCC; you don’t tie the pin directly to VCC.
