Does any project using Arduino to control the Hyperspectral imaging sensor like this?
http://headwallphotonics.web12.hubspot. … adwall.pdf
Is it possible to use Arduino to control the Hyperspectral imaging sensor?
Thanks.
Thanks.
If by control you mean being able to turn the power on and off via a FET the answer is yes. If you mean connecting to the Camera Link output and processing data, then an Arduino is hopelessly underpowered.
Of course if you can afford this sensor, you should be able to afford a ARM processor development board with Camera Link interface.
Thanks, I got it.
