Would i be possible to program the mini using the usb to serial and the RS232 Shifter? If so, would I need an external 5V power supply to both the RS232 Shifter and the Mini? What would the RS232 Shifter RX/TX pins hook up to on the mini? Does the RS232 Shifter supply 5V on it’s own?
*edit - The RS232 Shifter does not supply 5V, but I still am not sure if its possible to program the mini in this way.
Ordered a FTDI cable, but I’m impatient and just wondering.
I’m hoping to find out if you were ever able to figure this out. I found the thread through a forum search because I am considering buying a Pro Mini as well, but if there are installation issues I might back off and go another direction. Right now a majority of my experience has been with moisture products so I am trying to branch out a little bit. Have you heard of [wagner meters?](http://www.wagnermeters.com)
