I get "Could not get target status" message when I
When I am debugging , I get “Could not get target status” message when I hit run.
Single stepping works fine sometimes and sometimes gives the same
message.what is this msg?
I checked the micro it is ok! about programmer I don’t know what am i doing for ?
Right click your’s project file,select option–>general—>target(select which microcontroller u r using),after that compile it.
by
naz
tanx for your reply,
I did that but I don’t know what is the problem,do you think my programmer or the cable of JTAG programmer or something else has a problem ?
