I getting error message
Happens in an ESP32 Sparkfun board.
_i2cPort->end();
end doesn’t exist.
Please help. Thank!!!
Thanks for reaching out to us on this.
Please share the code you are using and more information about your device set-up so we may be able to assist you…though from a preliminary look, the library uses the end() function and the esp cannot compile…try updating to the latest libraries for your product(s) first, then post more info if that doesn’t work.
Hope this helps, and happy sparking!
