Qwiic ESP32 Thing WROOM no i2C devices showing up
Hello All - I am using an ESP32 Thing Wroom with the Sparkfun SGP30 the red power light comes on the sensor when plugged in, but none of the sample code works, they all fail with no sensor found errors. So I used one of the i2c enumerator examples and no devices are found. I also tried a TMP102 and had the same issue. I have swapped Qwiic cables just to be sure as well.
The ESP32 Blink LED example works and I can get the ESP32 on WiFi.
Any help would be appreciated on how to proceed.
-Joe
I had a bent pin in the QWIIC connector…
Lesson learned, check the pins!
-Joe
