I need help choosing the right equipment :)
My name is Curro, and I am a Food Scientist. Part of my work involves analyzing fermentation data logs, which I have been doing using a DrDAQ PicoLog and its respective sensors with a Raspberry Pi. I find this setup convenient due to its user-friendly interface and ease of use, especially since I am unfamiliar with writing code and prefer to avoid it if possible.
Colleagues who are more knowledgeable about computing have recommended that I switch to using sparkfun sensors. According to them, DrDAQ is outdated, and Sparkfun offers an impressive range of products. I am reaching out to with the following questions:
  • Would you recommend using a Raspberry Pi 4 with your sensors?
  • Do you offer any user interfaces that can easily log data such as temperature, oxygen, pH, humidity and Co2?
  • Which of your products would you recommend as a data logger?
Any advice you can provide would be greatly appreciated.
Thank you everyone in advance!
You can consider the following sparkfun sensors.
For data logging purpose, you can use Raspberry pi 4, as per your plan. But in my opinion, ESP32 will be more cost effective.
Hey there! Thank you for your answer!
I would need the sensors to be submerged in a liquid while tracking.
Would the following system work?, apologies for my ignorance in advance :slight_smile:
DataLogger IoT - 9DoF
Connected with Qwiic to:
Temperature Sensor Water Proof (how to connect?)
And from Atlas Scientific:
BNC pH Sensor
Disolved Oxygen Electrode
Co2 Sensor
Could that work?
Thanks in advance! :slight_smile:
Hi ,
Not sure if i am posting in the right place so apologies in advance.
I also need help selecting equipment.
I am using a PI to instruct relays to control a tram but i need the relay’s to send a 24v signal and the PI is only 3-5 , what do i need to get.
Thanks in advance
It will be easiest to simply find some relays (or their solid state equivalents) that can use the 3-5 volt triggers.
https://www.opto22.com/products/dc60s3
