Will the SparkFun DataLogger IoT auto-detection & log data from the Indoor Air Quality Combo Sensor (sen-25200)?
I don’t see that on the list of compatible parts, it probably won’t work. ![]()
If you can connect SDA,SCL,VCC and GND of the SparkFun DataLogger IoT with those of SparkFun Indoor Air Quality Combo Sensor - SCD41, SEN55 (Qwiic) and write code, the setup must work.
I plan to get the Sen54 from DigiKey and a Adafruit 5V boast adapter. This way I can be sure the Smartfun DataLogger will recognize it. I should be getting data over the USB without writing any code.
