Hi, i have a problem with I2c Address of BendLabs
how about a bit more information… so we can try to help:
what is the problem?
what does not work?
what is your setup hardware/software?
what error messages (if any)?
what have you tried ?
I connected two bendLabs to an Arduino. The first has a default I2C address, while the second has an address of 45. Using the sample code of the SparkFun_Displacement_Sensor_Arduino_Library library. h does not update my two sensor readings
SparkFun Displacement Sensor Example
No sensor detected. Check wiring. Freezing…
How can I fix it?
Both Sparkfun products with Bendlabs have been retired a while ago. Maybe try more up to date code from Bendlabs themselves : Bend Labs · GitHub
Hi @FrancescaDo ,
Did you try: myFlexSensor.begin(0x45) ?
If the address is 45 decimal (not hex), try myFlexSensor.begin(45)
