ID-20LA or comp. that works with Schlage 7410 cards?
i was just wondering if the ID-20LA (or any RFID sensor/ic carrried by sparkfun would work with my Schlage 7410 cards. i have tried multiple sensors and pcbs (hz-1045, rdm6300, ect) from other sources and none of them want to read the cards that also have a direct serial style output for further embedded intergration. has anyone test these modules with these sepefic cards?
It depends on the communication protocol and working frequency of your cards.
I would not expect this to work.
The ID-20LA accepts EM4001 cards. (EM4100 protocol description).
The Schlage 7410 cards use 26 bits (125kHz Standard) / H10301(The Standard 26 bit Format).
Completely different card format layout.
Search Google for “H10301 card reader” in your area
thanks ill give that a go! i thought EM4001 just ment read only… thanks for the time!
