I wanted to know how one would increase the survey time from 60-120 secs to any particular number. The docs for the ZED-F9P show that survey mode can last any arbitrary amount of time, so I assume there is some mechanism in place that limits it to 120 secs. My goal is get a better location estimate for the base station.
I think what you are looking for is here:
https://drotek.gitbook.io/rtk-f9p-posit … n-accuracy
I think you just need to change the value in legend #4 to 120.
I hope this helps.
Thank you for the info. Would you happen to know how to get the settings to stay once the device is power cycled? Storing to the non volatile memory does not seem to keep the settings.
Unless you save the configuration to the module it won’t last through a power cycle. Check the U-center users guide at the link below for information on saving configurations.
WARNING
Be careful in U-center, it’s possible to change settings that will cause the RTK Surveyor to not work.
Neither these instructions or the ones from the integration manual seem to work for the surveyor. I’ve tried saving the configurations from both the standard and ublox 9 configuration menu and each time the power switch is flipped the configuration is lost.
