Independent load sensors
Thank you in advance !
I want to make an array of load sensors, to measure weight independent from one another, in turn outputing a measurement to a LCD or some other display.
I want all the load sensors to be small, portable and interconnected to a microprocessor.
Any ideas ? I saw some flexible sensor resistors, and an adrino pc I could cause. Please advise
How small do you need the sensors to be? What load ranges are you measuring? Without that information, it’s difficult to give good advice.
That said, you could try simple ratiometric load cells like the FX1901.
