Intel Dual Band Wireless - AC 8265
Can any tell me what is the correct antenna adapter for the Intel Dual Band Wireless - AC 8265?
Do you have an existing antenna you’d like to connect or are you needing two antennas?
If you have an existing antenna, you will need a U.FL adapter cable with a connector on one end that matches your antennas. (Usually RP-SMA for WiFi antennas, although some antennas are SMA or another type of connector.)
We have a SMA and RP-SMA adapter cable below.
  • - [[Interface Cable SMA to U.FL](https://www.sparkfun.com/products/9145) (WRL-09145)
  • - [[Interface Cable RP-SMA to U.FL](https://www.sparkfun.com/products/662) (WRL-00662)
  • [/list]
    If you’re just looking for a pair of antennas that don’t need any adapters, a pair of these will work:
  • - [[Molex 2.4GHz/5GHz Wi-Fi Antenna (100mm)](https://www.sparkfun.com/products/15877)
  • [/list]](https://www.sparkfun.com/products/15877)](https://www.sparkfun.com/products/662)](https://www.sparkfun.com/products/9145)
