SKU: COM-14236
IOT Power relay
What is the make and model of the relay inside this device? I’d like that information so that I can get the datasheet for the relay itself to determine the approximate number of operations (life) under conditions other than those given in the datasheet for the entire device, which only says 400,000 operations at 12A resistive and 5 million at no load. There’s nothing about operations at other loads or inductive loads.
