For some reason, my JTAG quit communicating. LPC2148. JLink.exe says “Could not find a device on JTAG chain”. I am not getting a correct core ID. Another JTAG board works, so it is not the driver, or cable etc.
Yes, there is a 10K pulldown. On my board it is a DBG_E jumper enabling the pulldown. It is High with the JTAG cable plugged in though, and goes low when I unplug the JTAG cable.
I should have said: it needs a low-level on RTCK during reset.
As far as I know, RTCK is an output for the LPC and an input for the JTAG cable, so the JTAG cable should not cause it to go high. So I don’t know what is happening.
Other stuff to check:
Is the bootloader still working? I just read on the LPC2000 mailing list that a corrupted bootloader can result in JTAG no longer working.
Did you enable code protection? I remember reading somewhere that JTAG is disabled when code protection is enabled. I think you can clear this by doing a full erase using the Philips ISP utility.
In case you’re using a header board, is it still properly seated on its motherboard?
Did you try to remove and re-apply power to your board?
Thanks! I guess i needed a reset with that pin low, (with the JTAG cable removed). I tried probably every other sequence but that! Looks like it works again.
