JTAG firmware upgrade problem
We are currently attempting to use an olimex jtag with avr studio 4.09. Upon starting avr studio we were prompted to upgrade the firmware for the olimex jtag.
We then followed the instructions given by avr studio 4.09 to close avr studio and avr prog started in order to load the updated firmware. Part way through the process it said that it had failed and now when trying to use avr prog again it says “No supported board found”. The LED on the jtag device now remains unlit regardless of what we do.
Please help!!
Thanks again Chris and Andrew
you probably had power supply glitch or something else which iterrupted the upgrade, bad luck
check on our web how manually to activate bootloader and to load the new firmware
Tsvetan
