Hello, As mentioned I just purchased the Arduino wifi shield and it will not work…
I am sure this is an easy fix and others have had this problem before.
Received the new wifi shield and plugged it into my Arduino uno R3 pcb. Powered it all up and using the IDE 1.0.5 I loaded the WiFiWebClient sketch, this is what I got back from the serial screen.
Attempting to connect to SSID: mruby
Connected to wifi
SSID: mruby
IP Address: 192.168.1.3
signal strength (RSSI) : -55 dBm
Starting connection to server…
disconnecting from server.
Seems I get connected then get disconnected, Am I missing something?
Thanks, mruby
