L6470 Autodriver: Occasionally runs backwards
It is more than that, actually.
First, everything on my telescope was working correctly, so I seriously doubt it is the sketch, but…
Recently it has started to run backwards. That is, opposite the commanded direction. For example, if I command backwards it runs backwards. Then if I command forwards it runs backwards .
And it also sometimes “chatters”. That is it sits there are jogs back and forth a few degrees.
Any ideas? is this a torque problem?
I think I fixed the problem.
Hard to believe, but the locking ring on one of the connectors to the problem motor was slightly loose. I tightened it and it started behaving correctly.
I will be exercising it here to make sure.
Glad to see that the issue may have been worked through. Feel free to post again if things seem astray again.
