LED - RGB Addressable - Mechanical info, power consumption and absolute maximum ratings missing
Hello!
I am considering RGB addressable LEDs I found on Sparkfun site:
https://www.sparkfun.com/products/12999
https://www.sparkfun.com/products/12986
https://www.sparkfun.com/products/12877
but I noticed that the datasheets lack mechanichal drawings as well as absolute maximum ratings and current consumption.
Has anyone managed to get these information?
Thank you!
Antonio
Hi Antonio, and thanks for posting.
The absolute maximum voltage for power is 6 volts. Unfortunately the provided data sheet is all the information we have on these components.
Hi Chris,
thank you for you answer.
The need for info (especially mechanical ones) is, of course, because I shall consider - or maybe draw from scratch - a suitable footprint for the LEDs in the PCB editor.
Also knowing current draw at maximum brightness would be good.
I hope someone that has experience with them can provide some extra hint.
Thank you again!
Antonio
