Can anyone tell me where I can find the liquid crystal library " SparkSoftLCD.h " to include in my code ??
It’s propably part of a ZIP file.
I’m relatively new at this and not to familiar with the Git-Hub or Sparkfun sites yet.
I would be very thank full for any help.
Hi johannesvk,
That library appears to be a user-created library for certain SparkFun Serial LCDs. The [GitHub Repository has not been updated in six years so it may not be compatible with new versions of Arduinos or our new Serial Enabled LCDs like this [16x2 SerLCD.
You will most likely have to manually install that library or use the ZIP library installer tool in Arduino. We cover both installation methods in [this tutorial.
If you have one of our newer SerLCDs, we recommend using the [SparkFun SerLCD Library.
I hope this helps you find and install the correct Arduino library. Let us know if you have any other questions and we would be happy to help.](https://learn.sparkfun.com/tutorials/avr-based-serial-enabled-lcds-hookup-guide/sparkfun-serlcd-library)](Installing an Arduino Library - SparkFun Learn)](GitHub - thisdroneeatspeople/SparkSoftLCD: Single-pin Arduino Serial Interface Library for SparkFun Serial LCDs)](GitHub - thisdroneeatspeople/SparkSoftLCD: Single-pin Arduino Serial Interface Library for SparkFun Serial LCDs)
