bigglez:
Is this Pulsonix free? Is this Electra free?leon_heller:
There are much better tools, of course, like the Pulsonix software I use. Pulsonix uses the Electra autorouter, which is available for Eagle.If not what does it cost?
Pulsonix starts at about twice the price of Eagle Professional (2,000 GBP, IIRC, vs $1494 for Eagle). It’s good value, as designs can typically be completed in a fraction of the time it takes with Eagle.
Electra starts at $645:
It’s far better than the Eagle autorouter, typically routing to 100% completion even on complex boards.
I’ve just imported the design into Pulsonix, and run the Design Rule Checker on it. It showed some placement errors:
DRC Errors Report
Report Written : 10/01/2009 05:05:40
Design Path : C:\Documents and Settings\User\Desktop\Sub_Amp_Board\Board.pcb
Design Title :
Created : 10/01/2009 04:53:59
Last Saved : 10/01/2009 04:56:53
Editing Time : 11 min
Board to Pad Error (B-P) Between (2.2- 0.0) and (2.2- 0.0+). Layer ‘Top’. Required 0.1- Actual 0.0+.
Board to Pad Error (B-P) Between (0.0 1.4-) and (0.0+ 1.4-). Layer ‘’. Required 0.1- Actual 0.0+.
Board to Pad Error (B-P) Between (2.4- 1.4-) and (2.4- 1.4-). Layer ‘’. Required 0.1- Actual 0.0+.
Component to Component Error (Cm-Cm) Between (0.4 0.2) and (0.9+ 0.3+). Layer ‘Top’. Required 0.0 Actual 0.0.
Component to Component Error (Cm-Cm) Between (1.5- 1.3-) and (1.6- 0.9+). Layer ‘Top’. Required 0.0 Actual 0.0.
Board to Component Error (B-Cm) At (1.4- 0.2). Layer ‘Top’.
Board to Component Error (B-Cm) At (1.8 0.2). Layer ‘Top’.
Component to Component Error (Cm-Cm) Between (0.9+ 0.3+) and (1.3- 0.7-). Layer ‘Top’. Required 0.0 Actual 0.0.
Board to Component Error (B-Cm) At (0.4 1.5-). Layer ‘Top’.
Board to Component Error (B-Cm) At (1.2 1.5-). Layer ‘Top’.
Board to Component Error (B-Cm) At (2.0 1.5-). Layer ‘Top’.
Total:
5 Board to Component Error (B-Cm)
3 Board to Pad Error (B-P)
3 Component to Component Error (Cm-Cm)
Number of errors found : 11
The following rules were not checked:
All On Grid Rules
All Keep In/Out Rules
All Manufacturing Rules
All Net Rules
All acceptance rules were checked.
No net class spacing rules defined.
No net class pair rules defined.
---------------- End Of Report ----------------
The board-component errors probably don’t matter, the others probably do. They should have been flagged by Eagle.
Leon
