I’m using an Arduino Uno R3, a Sparkfun HX711 and the Phidgets load cell 5 kg. Because I’m new to this stuff, I thought it’s the easiest to start with the SparkFun Codes https://learn.sparkfun.com/tutorials/lo … -guide/all
My issue right now is that my determined calibration factor only works for the weight I calibrated with. As soon as I place other weights on my load cell it shows wrong weights.
I’m not sure where the issue is, whether it’s the hardware or the code!
Double check how you have the load cell setup physically, the calibration weight and whatever you’re wanting to weigh later on must be in the exact same location on the load cell for it to produce accurate results.
I’m not using a plate, I place my weights on the load cell directly. I think they are in the same spot. Do you think it makes that much difference when the spot is not exactly the same?
The user Yellowdog had a good post about another product that might be helpful in your case, you can see it in the link below. Give that physical setup a try, that should resolve your issues.
