Hi, the LOG button of my unit does not seem to work. I do not feel any ‘tick’ nor motion when pressing it, and nothing changes on the logging when pressing it nevertheless. Did I miss something ? Should I open the box to try solving this problem which is likely a simple mechanical issue ?
(Note: the Reset and Boot buttons work well)
That sounds like a good next step - open it up and see if something obvious is going on with the button
Maybe upload a photo of the soldering in the area/pins if you can’t find something right away
By the way, the button was indeed soldered a bit in diagonal. We resoldered it straight and then it worked fined.
Hi Mathieu (@mathieu.lebreton ),
Thank you for the update, and apologies for the hassle. I am glad you got your unit working. It was a fun product to design - the X5 is such a great chip.
