This may be a long shot, but I need to flip the logic of the logomatic from non-inverted to inverted to match the uBlox SAM LS GPS. Don’t ask how long it took to figure this one out. I can get the logomatic to work fine with the non-inverted logic on its own, also I’ve been reading the GPS several months now with no problems on its own too, so I know this isn’t a hardware problem by any means. I combed through the logomatic code but couldn’t find how or where the logic is defined. Does anyone know, can I change the logic in the logomatic software? Or, is there a hardware solution? I’m researching changing the logic of the GPS, but that is leading to dead-ends as well.
Any friends have a good answer?
Oh by the way, here’s my project so you know it’s not just a random question that won’t ever go anywhere … this is going on a UAV of sorts that is emulating how birds soar for hours on end: http://soaring.goosetechnologies.com
Thanks for the help.
Dan
