logomatic rtc implementation
Hello all,
I am trying to change to given logomatic code to use the rtc, put a date and time stamp on a text file, and give that file the date as its name. The original code comes with three modes of operation, and I am trying to just use mode 1(which is the second mode). I suck at programming, and I have taken a basic introductory course in c. Now, with that being said I have figured out most of what I want to do with this thing, but perhaps somebody can give me a nudge in the right direction. Here is the code
 * Logomatic V2 Firmware
 * Sparkfun Electronics 2008
 * 		     Header Files
#include <stdio.h>
#include <stdint.h>
#include <string.h>
#include "LPC21xx.h"
//UART0 Debugging
#include "serial.h"
#include "rprintf.h"
//Needed for main function calls
#include "main_msc.h"
#include "fat.h"
#include "armVIC.h"
#include "itoa.h"
#include "rootdir.h"
#include "sd_raw.h"
 * 		     Global Variables
#define ON	1
#define OFF	0
char RX_array1[512];
char RX_array2[512];
char log_array1 = 0;
char log_array2 = 0;
short RX_in = 0;
char get_frame = 0;
unsigned char flag = 0;
signed int stringSize;
struct fat_file_struct* handle;
struct fat_file_struct * fd;
char stringBuf[256];
// Default Settings
static char mode = 1;
static char asc = 'Y';
static int baud = 9600;
static char trig = '
I am having a hard time getting it to open the same file for mulitple logs. I want to create a new file at say midnight every night, so that it why the file names will be date stamped. I tried some things in that while loop in main, but I was unsuccessful. Keep in mind that I lack experience so most of this is the original just hacked on by me.
Thank you;
static short frame = 100;
  •   Function Declarations
void set_time(void);
void Initialize(void);
void setup_uart0(int newbaud, char want_ints);
void mode_0(void);
void mode_1(void);
void mode_2(void);
void mode_action(void);
void Log_init(void);
void test(void);
void stat(int statnum, int onoff);
void AD_conversion(int regbank);
void feed(void);
static void IRQ_Routine(void) attribute ((interrupt(“IRQ”)));
static void UART0ISR(void); //attribute ((interrupt(“IRQ”)));
static void UART0ISR_2(void); //attribute ((interrupt(“IRQ”)));
static void MODE2ISR(void); //attribute ((interrupt(“IRQ”)));
void rtc_int(void) attribute ((interrupt(“IRQ”)));
void FIQ_Routine(void) attribute ((interrupt(“FIQ”)));
void SWI_Routine(void) attribute ((interrupt(“SWI”)));
void UNDEF_Routine(void) attribute ((interrupt(“UNDEF”)));
void fat_initialize(void);
void delay_ms(int count);
  •       	MAIN
int main (void)
int i;
char name[32];
int count = 0;
set_time ();
enableFIQ();
Initialize();
setup_uart0(9600, 0);
fat_initialize();
// Flash Status Lights
for(i = 0; i < 5; i++)
	stat(0,ON);
	delay_ms(50);
	stat(0,OFF);
	stat(1,ON);
	delay_ms(50);
	stat(1,OFF);
Log_init();
count++;
string_printf(name,"%04d-%02d-%02d.txt", YEAR, MONTH, DOM);
while(root_file_exists(name))
	count++;
	if(count == 250)
		rprintf("Too Many Logs!\n\r");
		while(1)
			stat(0,ON);
			stat(1,ON);
			delay_ms(1000);
			stat(0,OFF);
			stat(1,OFF);
			delay_ms(1000);
	string_printf(name,"LOG%02d.txt",count);
handle = root_open_new(name);
sd_raw_sync();
if(mode == 0){ mode_0(); }
else if(mode == 1){ mode_1(); }
	return 0;
  •       Initialize
#define PLOCK 0x400
void set_time(void)
PCONP |= (1<<9); //Ensure RTC is powered
CCR = 0x13; //Turn off RTC
YEAR = 2015;
MONTH = 06;
DOM = 15; //Day of Month
HOUR = 8;
MIN = 52;
SEC = 0;
CCR = 0x11; //Turn RTC back on
rprintf_devopen(putc_serial0);
PINSEL0 = 0xCF351505;
PINSEL1 = 0x15441801;
IODIR0 |= 0x00000884;
IOSET0 = 0x00000080;
S0SPCR = 0x08;  // SPI clk to be pclk/8
S0SPCR = 0x30;  // master, msb, first clk edge, active high, no ints
void feed(void)
PLLFEED=0xAA;
PLLFEED=0x55;
char temp;
if(RX_in < 512)
	RX_array1[RX_in] = U0RBR;
	RX_in++;
	if(RX_in == 512) log_array1 = 1;
else if(RX_in >= 512)
	RX_array2[RX_in-512] = U0RBR;
	RX_in++;
	if(RX_in == 1024)
		log_array2 = 1;
		RX_in = 0;
temp = U0IIR; // Have to read this to clear the interrupt
VICVectAddr = 0;
char temp;
temp = U0RBR;
if(RX_in == 0)
memset (RX_array1, 0, 512); // This clears the RX_array to make way for new data
if(RX_in < 512)
RX_array1[RX_in] = temp;
RX_in++;
	if(temp == trig)
		RX_array1[RX_in] = 10; // delimiters
		RX_array1[RX_in + 1] = 13;
		log_array1 = 1;
		RX_in = 0;
	RX_array2[RX_in - frame] = temp;
	RX_in++;
	if(RX_in == 2*frame)
		RX_array2[RX_in - frame] = 10; // delimiters
		RX_array2[RX_in + 1 - frame] = 13;
		log_array2 = 1;
		RX_in = 0;
temp = U0IIR; // have to read this to clear the interrupt
VICVectAddr = 0;
char a;
int j;
stat(0,ON);
for(j = 0; j < 5000000; j++);
stat(0,OFF);
a = U0RBR;
a = U0IIR;  // have to read this to clear the interrupt
while(1);
stat(0,ON);
baud = newbaud;
U0LCR = 0x83; // 8 bits, no parity, 1 stop bit, DLAB = 1
if(baud == 1200)
	U0DLM = 0x0C;
	U0DLL = 0x00;
else if(baud == 2400)
	U0DLM = 0x06;
	U0DLL = 0x00;
else if(baud == 4800)
	U0DLM = 0x03;
	U0DLL = 0x00;
else if(baud == 9600)
	U0DLM = 0x01;
	U0DLL = 0x80;
else if(baud == 19200)
	U0DLM = 0x00;
	U0DLL = 0xC0;
else if(baud == 38400)
	U0DLM = 0x00;
	U0DLL = 0x60;
else if(baud == 57600)
	U0DLM = 0x00;
	U0DLL = 0x40;
else if(baud == 115200)
	U0DLM = 0x00;
	U0DLL = 0x20;
U0FCR = 0x01;
U0LCR = 0x03;
if(want_ints == 1)
	enableIRQ();
	VICIntSelect &= ~0x00000040;
	VICIntEnable |= 0x00000040;
	VICVectCntl1 = 0x26;
	VICVectAddr1 = (unsigned int)UART0ISR;
	U0IER = 0x01;
else if(want_ints == 2)
	enableIRQ();
	VICVectCntl2 = 0x26;
	VICVectAddr2 = (unsigned int)UART0ISR_2;
	U0IER = 0X01;
else if(want_ints == 0)
	VICIntEnClr = 0x00000040;
	U0IER = 0x00;
if(statnum) // Stat 1
if(onoff){ IOCLR0 = 0x00000800; } // On
else { IOSET0 = 0x00000800; } // Off
else // Stat 0
if(onoff){ IOCLR0 = 0x00000004; } // On
else { IOSET0 = 0x00000004; } // Off
void Log_init(void)
int x, mark = 0, ind = 0;
char temp;
// signed char handle;
if(root_file_exists("LOGCON.txt"))
	//rprintf("\n\rFound LOGcon.txt\n");
	fd = root_open("LOGCON.txt");
	stringSize = fat_read_file(fd, (unsigned char *)stringBuf, 512);
	stringBuf[stringSize] = '\0';
	fat_close_file(fd);
else
	//rprintf("Couldn't find LOGcon.txt, creating...\n");
	fd = root_open_new("LOGCON.txt");
	if(fd == NULL)
	 	rprintf("Error creating LOGCON.txt, locking up...\n\r");
	 	while(1)
			stat(0,ON);
			delay_ms(50);
			stat(0,OFF);
			stat(1,ON);
			delay_ms(50);
			stat(1,OFF);
	strcpy(stringBuf, "MODE = 1\r\nASCII = Y\r\nBaud = 4\r\nTrigger Character = $\r\nText Frame = 100\r\n");
	stringSize = strlen(stringBuf);
	fat_write_file(fd, (unsigned char*)stringBuf, stringSize);
	sd_raw_sync();
for(x = 0; x < stringSize; x++)
	temp = stringBuf[x];
	if(temp == 10)
		mark = x;
		ind++;
		if(ind == 1)
			mode = stringBuf[mark-2]-48; // 0 = auto uart, 1 = trigger uart
			rprintf("mode = %d\n\r",mode);
		else if(ind == 2)
			asc = stringBuf[mark-2]; // default is 'N'
			rprintf("asc = %c\n\r",asc);
		else if(ind == 3)
			if(stringBuf[mark-2] == '1'){ baud = 1200; }
			else if(stringBuf[mark-2] == '2'){ baud = 2400; }
			else if(stringBuf[mark-2] == '3'){ baud = 4800; }
			else if(stringBuf[mark-2] == '4'){ baud = 9600; }
			else if(stringBuf[mark-2] == '5'){ baud = 19200; }
			else if(stringBuf[mark-2] == '6'){ baud = 38400; }
			else if(stringBuf[mark-2] == '7'){ baud = 57600; }
			else if(stringBuf[mark-2] == '8'){ baud = 115200; }
			rprintf("baud = %d\n\r",baud);
		else if(ind == 4)
			trig = stringBuf[mark-2]; // default is $
			rprintf("trig = %c\n\r",trig);
		else if(ind == 5)
			frame = (stringBuf[mark-2]-48) + (stringBuf[mark-3]-48) * 10 + (stringBuf[mark-4]-48)*100;
			if(frame > 510){ frame = 510; } // up to 510 characters
			rprintf("frame = %d\n\r",frame);
void mode_0(void) // Auto UART mode
rprintf(“MODE 0\n\r”);
setup_uart0(baud,1);
stringSize = 512;
mode_action();
rprintf(“Exit mode 0\n\r”);
void mode_1(void)
rprintf(“MODE 1\n\r”);
setup_uart0(baud,2);
stringSize = frame + 2;
mode_action();
int j;
char output[1024];
while(1)
	uint32_t ctime0_val = CTIME0;
	uint32_t ctime1_val = CTIME1;
	uint32_t ctime2_val = CTIME2;
	unsigned int seconds = (0x0000003f & ctime0_val);         // Bit masking to read the time values from the appropriate
	unsigned int minutes = (0x00003f00 & ctime0_val) >> 8;    // registers, and also placing those values in the correct
	unsigned int hours = (0x001f0000 & ctime0_val) >> 16;     // slot to display a readable time and date
	unsigned int dom = (0x0000001f & ctime1_val);
	unsigned int month = (0x00000f00 & ctime1_val) >> 8;
	unsigned int year = (0x0fff0000 & ctime1_val) >> 16;
	if(log_array1 == 1)
		stringSize = sprintf(output, "%04d-%02d-%02d %02d:%02d:%02d, %s\n\r", year, month, dom, hours, minutes, seconds, (unsigned char *)RX_array1);
		stat(0,ON);
		if(fat_write_file(handle, output, stringSize) < 0)
			while(1)
				stat(0,ON);
				for(j = 0; j < 500000; j++)
				stat(0,OFF);
				stat(1,ON);
				stat(1,OFF);
		sd_raw_sync();
		stat(0,OFF);
		log_array1 = 0;
	if(log_array2 == 1)
		stat(1,ON);
		if(fat_write_file(handle,(unsigned char *)RX_array2, stringSize) < 0)
			while(1)
				stat(0,ON);
				stat(0,OFF);
				stat(1,ON);
				stat(1,OFF);
		sd_raw_sync();
		stat(1,OFF);
		log_array2 = 0;
	if((IOPIN0 & 0x00000008) == 0) // if button pushed, log file & quit
		VICIntEnClr = 0xFFFFFFFF;
		if(RX_in < 512)
			fat_write_file(handle, output, stringSize);
			sd_raw_sync();
			fat_write_file(handle, (unsigned char *)RX_array2, RX_in - 512);
			sd_raw_sync();
		while(1)
			stat(0,ON);
			for(j = 0; j < 500000; j++);
			stat(0,OFF);
			stat(1,ON);
			stat(1,OFF);
void test(void)
rprintf("\n\rLogomatic V2 Test Code:\n\r");
rprintf("ADC Test will begin in 5 seconds, hit stop button to terminate the test.\r\n\n");
delay_ms(5000);
while((IOPIN0 & 0x00000008) == 0x00000008)
	// Get AD1.3
	AD1CR = 0x0020FF08;
	AD_conversion(1);
	// Get AD0.3
	AD0CR = 0x0020FF08;
	AD_conversion(0);
	// Get AD0.2
	AD0CR = 0x0020FF04;
	AD_conversion(0);
	// Get AD0.1
	AD0CR = 0x0020FF02;
	AD_conversion(0);
	// Get AD1.2
	AD1CR = 0x0020FF04;
	AD_conversion(1);
	// Get AD0.4
	AD0CR = 0x0020FF10;
	AD_conversion(0);
	// Get AD1.7
	AD1CR = 0x0020FF80;
	AD_conversion(1);
	// Get AD1.6
	AD1CR = 0x0020FF40;
	AD_conversion(1);
	delay_ms(1000);
	rprintf("\n\r");
rprintf("\n\rTest complete, locking up...\n\r");
while(1);
int temp = 0, temp2;
if(!regbank) // bank 0
	AD0CR |= 0x01000000; // start conversion
	while((temp & 0x80000000) == 0)
		temp = AD0DR;
	temp &= 0x0000FFC0;
	temp2 = temp / 0x00000040;
	AD0CR = 0x00000000;
else	    // bank 1
	AD1CR |= 0x01000000; // start conversion
		temp = AD1DR;
	temp &= 0x0000FFC0;
	AD1CR = 0x00000000;
rprintf("%d", temp2);
rprintf("   ");
if(!sd_raw_init())
rprintf(“SD Init Error\n\r”);
while(1);
if(openroot())
	rprintf("SD OpenRoot Error\n\r");
int i;
count *= 10000;
for(i = 0; i < count; i++)
asm volatile (“nop”);
Thank you
That one line is very curious:
because I don’t see anything that is going to alter the existence of that file if it exists and I don’t see anything that’s going to break out of that loop.
But, might I suggest that you do some googling on “time stamped log file in c” or similar and then pare your code down to just doing some log file creation and get that ironed out without everything else getting in the way of debugging your file detection and creation.
DanV Thank you for the reply. I already have it logging files with a time stamp. There is section towards the bottom of the code with the required bit masking to extract the time from certain registers in the chip. I also have it naming the file as the date, which is what I want. I am just having trouble figuring out how to make it close the file at a specific time and open a new one at that time. Like I said before, programming is not my forte.
On a similar type logging project I always closed the file after writing to it.
When writing to the file, I generate the logfile name and open it for append (or you could check if it exists and create it if not), write to it and close it.
Once again, Thank you DanV for replying. I have another issue. I have done what you suggested with open append and close, but the only problem is that the old data gets erased with every log. I have used our friend google and the “fix” that I found is to use “a” when opening the file. This does not seem to work in the Winarm toolchain. I appreciate any help. Here is the updated code
 * 		     Header Files
#include <stdio.h>
#include <stdint.h>
#include <string.h>
//UART0 Debugging
#include "serial.h"
#include "fat.h"
#include "armVIC.h"
#include "itoa.h"
#include "sd_raw.h"
 * 		     Global Variables
#define ON	1
#define OFF	0
short RX_in = 0;
char get_frame = 0;
// Default Settings
void mode_0(void);
void mode_1(void);
void mode_2(void);
void test(void);
void feed(void);
  •       	MAIN
int main (void)
int i;
//char name[32];
//int count = 0;
set_time ();
enableFIQ();
Initialize();
fat_initialize();
	stat(0,ON);
	delay_ms(50);
	stat(0,OFF);
	stat(1,ON);
	delay_ms(50);
	stat(1,OFF);
Log_init();
//count++;
/*while(root_file_exists(name))
	count++;
	if(count == 250)
		while(1)
			stat(0,ON);
			stat(1,ON);
			delay_ms(1000);
			stat(0,OFF);
			stat(1,OFF);
			delay_ms(1000);
//handle = root_open_new(name);
sd_raw_sync();
return 0;
  •       Initialize
#define PLOCK 0x400
void set_time(void)
YEAR = 2015;
MONTH = 06;
DOM = 17; //Day of Month
HOUR = 23;
MIN = 59;
SEC = 0;
void feed(void)
PLLFEED=0xAA;
PLLFEED=0x55;
char temp;
if(RX_in < 512)
	RX_in++;
	RX_in++;
	if(RX_in == 1024)
		log_array2 = 1;
		RX_in = 0;
VICVectAddr = 0;
char temp;
temp = U0RBR;
if(RX_in == 0)
if(RX_in < 512)
RX_in++;
	if(temp == trig)
		log_array1 = 1;
		RX_in = 0;
	RX_in++;
		log_array2 = 1;
		RX_in = 0;
VICVectAddr = 0;
char a;
int j;
stat(0,ON);
stat(0,OFF);
a = U0RBR;
while(1);
stat(0,ON);
baud = newbaud;
if(baud == 1200)
	U0DLM = 0x0C;
	U0DLL = 0x00;
	U0DLM = 0x06;
	U0DLL = 0x00;
	U0DLM = 0x03;
	U0DLL = 0x00;
	U0DLM = 0x01;
	U0DLL = 0x80;
	U0DLM = 0x00;
	U0DLL = 0xC0;
	U0DLM = 0x00;
	U0DLL = 0x60;
	U0DLM = 0x00;
	U0DLL = 0x40;
	U0DLM = 0x00;
	U0DLL = 0x20;
U0FCR = 0x01;
U0LCR = 0x03;
if(want_ints == 1)
	enableIRQ();
	U0IER = 0x01;
	enableIRQ();
	U0IER = 0X01;
	U0IER = 0x00;
else // Stat 0
void Log_init(void)
char temp;
	fat_close_file(fd);
else
	if(fd == NULL)
	 	while(1)
			stat(0,ON);
			delay_ms(50);
			stat(0,OFF);
			stat(1,ON);
			delay_ms(50);
			stat(1,OFF);
	sd_raw_sync();
	if(temp == 10)
		mark = x;
		ind++;
		if(ind == 1)
		else if(ind == 2)
		else if(ind == 3)
		else if(ind == 4)
		else if(ind == 5)
stringSize = 512;
mode_action();
void mode_1(void)
mode_action();
int j;
char output[1024];
char name[32];
while(1)
	//uint32_t ctime2_val = CTIME2;
	if(root_file_exists(name))
		handle = root_open(name);
		if(log_array1 == 1)
			stat(0,ON);
				while(1)
					stat(0,ON);
					stat(0,OFF);
					stat(1,ON);
					stat(1,OFF);
			sd_raw_sync();
			stat(0,OFF);
			log_array1 = 0;
		fat_close_file(handle);
	else
		if(log_array1 == 1)
			stat(0,ON);
				while(1)
					stat(0,ON);
					stat(0,OFF);
					stat(1,ON);
					stat(1,OFF);
			sd_raw_sync();
			stat(0,OFF);
			log_array1 = 0;
	if(log_array2 == 1)
		stat(1,ON);
			while(1)
				stat(0,ON);
				stat(0,OFF);
				stat(1,ON);
				stat(1,OFF);
		sd_raw_sync();
		stat(1,OFF);
		log_array2 = 0;
	/*if((IOPIN0 & 0x00000008) == 0) // if button pushed, log file & quit
		if(RX_in < 512)
			sd_raw_sync();
			sd_raw_sync();
		while(1)
			stat(0,ON);
			stat(0,OFF);
			stat(1,ON);
			stat(1,OFF);
void test(void)
delay_ms(5000);
	// Get AD1.3
	AD1CR = 0x0020FF08;
	AD_conversion(1);
	// Get AD0.3
	AD0CR = 0x0020FF08;
	AD_conversion(0);
	// Get AD0.2
	AD0CR = 0x0020FF04;
	AD_conversion(0);
	// Get AD0.1
	AD0CR = 0x0020FF02;
	AD_conversion(0);
	// Get AD1.2
	AD1CR = 0x0020FF04;
	AD_conversion(1);
	// Get AD0.4
	AD0CR = 0x0020FF10;
	AD_conversion(0);
	// Get AD1.7
	AD1CR = 0x0020FF80;
	AD_conversion(1);
	// Get AD1.6
	AD1CR = 0x0020FF40;
	AD_conversion(1);
	delay_ms(1000);
	rprintf("\n\r");
while(1);
		temp = AD0DR;
	temp &= 0x0000FFC0;
	AD0CR = 0x00000000;
else	    // bank 1
		temp = AD1DR;
	temp &= 0x0000FFC0;
	AD1CR = 0x00000000;
rprintf("   ");
if(!sd_raw_init())
while(1);
if(openroot())
int i;
count *= 10000;
Near as I can tell you can try root_open_append() - I don’t know if that function is available to you, but it should be…
Kind of depends on what library / language you’re using.
Have a look at this thread:
https://forum.sparkfun.com/viewtopic.php?t=15876
DanV
You are freaken awesome. Thank you for taking the time to point me in the right direction. I had to go and alter the fat and rootdir libraries, but it was simple. Now I just have to clean up the code a lot, but as of right now it is working. When I have a cleaner version I will post it so somebody else doesn’t have to suffer. I am an EE student so I have focused more on math and physics than programming, but this project was a good learning experience.
Thank you
I don’t know about awesome, just glad to hear it’s working out for you.
You’re welcome…
