I noticed that the time required for starting the recording depends on the number of files on SD (more then 20 seconds if I have up to 20 - 25 files on MODE0 and also on Mode1). If I make logomatic to write always the same file (eg LOG0) is possible to reduce this times under 2 or 3 seconds?
I am inexperienced in C programming It would be a difficult change? Which file should be changed and how?
Many thanks in advance
