Will these radios work with facets used as a base/rover setup:
I cannot get them to work.
Any suggestions as to setting for both facets and radios would be greatly appreciated.
Also - if they are not compatible, that would be good to know.
They should work fine; did you runthrough our guide for the radios? Quick Start Guide - SparkFun LoRaSerial Product Manual
You’ll also configure the facet kike so Correction Transport - SparkFun RTK Product Manual (use the radio port)
Ok-thanks.
Just to confirm - the “enable radios” option in the facet configuration menu does not apply to external serial radios - only to ESPNow internal radios. Is that correct?
So the “enable radios” option should be turned off when using external serial radios connected to the JST radio port.
Correct - that’s for the internal esp-now radios, you’ll want to use the ‘ports’ menu ![]()
