I have tried to operate this module with the RadioHead library to make point-to-point communication, however I have not succeeded, can someone tell me if they have tried it? Or is this module only available for lorawan? I am attentive, thanks.
I already solved it, it really needs Sparkfun to document this integration better
Hi, I am having difficulty getting the module to do the same thing you explained above. Can you tell me what was your issue and how was if fixed. Any code would be helpful
