Hey,
I was playing around with LumiDrive LED Driver. The arduino code which was linked in hookup guide didn’t show any results at that time hence I tried changing the DATA_PIN and CLOCK_PIN.
Previous:
#define DATA_PIN 16
#define CLOCK_PIN 17
Changed:
#define DATA_PIN 27
#define CLOCK_PIN 28
Now, the usb drive and partition disappeared. I can try to reflash the bootloader and bring back to the initial state but I failed to find any referrences for that.
Also, my application required threading in python(it required reading from the console and a operation loop in parallel for keeping blinking operation alive until a request for any other pattern is input in the console) but I don’t think circuit python supports threading hence eventually I have to go for arduino and FastLED but I need to communicate serially over USB. And I don’t know which Serial to select or any require any additional settings.
Let me know if anyone has any view on this.
LumiDrive LED Driver: https://www.sparkfun.com/products/14779
Arduino code: https://cdn.sparkfun.com/assets/learn_t … rmware.zip
