Hello all - I have one of these. I know they are no longer sold, but I am hoping I can find some help here on the forum. It was brand new (I cut it out of the sealed plastic bag).
I have it connected to a Windows laptop with a TTL-to-USB adapter. I downloaded the latest version of Universal Reader Assistant 6.3
Here is the issue: It will not read in the normal mode (where you click “Read” on the “tag results” tab), I always get this error:
It WILL read if I go to the Tag Inspector tab and click read:
I am also able to write to tags using the other tabs (Write EPC, etc) and successfully read them back (again: ONLY in Tag Inspector, not in the general “Tag Results” view where you can read multiple tags at the same time)
So, this proves the hardware (and my serial USB board) works. I am powering the card from the USB adapter, but I have set the TX and RX power down to 4dBm (I have to put the tag directly on the board to get a read, but it works). So, that is not the problem.
I am using the on-board antenna, have selected antenna 01, and not changed the onboard jumper or tried to add an external antenna.
I tried Googling the error. Oddly enough, the search does return somewhat relevant hits related to Jadak software, but most of the resulting documents swap the word “parameter” for “value” (!) and seem to all be related with the newer M7E Hecto product
Example from https://www.jadaktech.com/wp-content/uploads/2024/06/TM_HECTO-UG-Rev_06142024.pdf
I don’t see why this would be a firmware issue, but I looked through the documentation for help and it said that Firmware was provided here. There are a lot of files at that link; I was not sure which to download. I also didn’t understand if/why a new license would be needed and didn’t want to mess anything up, so I did not pursue this yet.
Here’s what the help file said:
The section provides a means to upgrade the firmware and license of the connected reader.
- Firmware: Steps to update the Firmware-
- Click Choose File and navigate to the filesystem location where the firmware file is located.
- Select the firmware file and click Open.
- Click Update.
- Upon completion, a pop up message will come to indicate it has been completed.
- License: Steps to update the License-
- Give the ‘License Key’ generated for the reader in the provided space.
- Click Update.
Note : The latest firmware is always available on https://www.jadaktech.com/resources/rfid-document-library.
Note : This utility can be used to downgrade firmware also.
Here’s my firmware info:
RFID Engine : M6e Nano
COM/IP : COM6
Firmware Version : 1.07.03.17
Hardware Version : 30.00.00.02 Rev 0G
Serial Number : (redacted)
URA Version : 6.3.29.29
Mercury API Version : 1.37.3.29
Here’s a log. All I did here was connect to the board and performed two operations:
- I clicked “Read” on the Tag Inspector tab (with no tag nearby, so it timed out saying No Tag Found). This confirmed the board was connected and responding
- Then clicked “read” on the Tag Results tab, generating the error that I am posting about here.
06/15/2026 10:12:31.054 PM Sending
FF 00 03 1D 0C
06/15/2026 10:12:31.058 PM Received
FF 14 03 00 00 14 12 08 00 30 00 00 02 20 17 09
25 01 07 03 17 00 00 00 10 A6 6E
06/15/2026 10:12:31.132 PM Sending
FF 00 03 1D 0C
06/15/2026 10:12:31.139 PM Received
06/15/2026 10:12:31.155 PM Sending
FF 00 72 1D 7D
06/15/2026 10:12:31.164 PM Received
FF 01 72 00 00 2C 48 2B
06/15/2026 10:12:31.167 PM Sending
FF 00 67 1D 68
06/15/2026 10:12:31.169 PM Received
FF 01 67 00 00 0D B4 8C
06/15/2026 10:12:31.183 PM Sending
FF 00 71 1D 7E
06/15/2026 10:12:31.188 PM Received
FF 11 71 00 00 0D 0E 04 05 06 08 09 0B 0C 10 11
12 13 14 15 16 FF 12 16
06/15/2026 10:12:31.189 PM Sending
FF 01 62 01 BE BC
06/15/2026 10:12:31.193 PM Received
FF 07 62 00 00 01 01 86 0A 8C 00 00 8D 6A
06/15/2026 10:12:31.193 PM Sending
FF 01 62 01 BE BC
06/15/2026 10:12:31.197 PM Received
06/15/2026 10:12:31.198 PM Sending
FF 02 92 0A 8C 4B D5
06/15/2026 10:12:31.201 PM Received
FF 00 92 00 00 27 3B
06/15/2026 10:12:31.203 PM Sending
FF 02 94 0A 8C 2B 13
06/15/2026 10:12:31.211 PM Received
FF 00 94 00 00 47 FD
06/15/2026 10:12:31.212 PM Sending
FF 00 65 1D 6A
06/15/2026 10:12:31.234 PM Received
FF C8 65 00 00 00 0E 21 30 00 0E 08 30 00 0E 1C
80 00 0E 13 E8 00 0E 10 00 00 0E 1E 10 00 0E 03
80 00 0E 06 A0 00 0E 17 D0 00 0E 10 C8 00 0E 16
40 00 0E 0A 88 00 0E 07 68 00 0E 0E 70 00 0E 23
88 00 0E 24 50 00 0E 0C E0 00 0E 1A F0 00 0E 18
98 00 0E 0D A8 00 0E 1B B8 00 0E 11 90 00 0E 01
28 00 0E 14 B0 00 0E 05 D8 00 0D FF 98 00 0E 22
C0 00 0E 19 60 00 0E 08 F8 00 0E 21 F8 00 0E 1D
48 00 0E 04 48 00 0E 05 10 00 0E 15 78 00 0E 02
B8 00 0E 25 18 00 0E 1E D8 00 0E 12 58 00 0E 13
20 00 0E 00 60 00 0E 0B 50 00 0E 20 68 00 0E 0C
18 00 0E 1A 28 00 0E 01 F0 00 0E 25 E0 00 0E 09
C0 00 0E 0F 38 00 0E 17 08 00 0E 1F A0 5F F6
06/15/2026 10:12:31.237 PM Sending
FF 01 62 01 BE BC
06/15/2026 10:12:31.246 PM Received
FF 07 62 00 00 01 0A 8C 0A 8C 00 00 54 B4
06/15/2026 10:12:31.247 PM Sending
FF 01 62 01 BE BC
06/15/2026 10:12:31.251 PM Received
06/15/2026 10:12:31.251 PM Sending
FF 02 6B 05 10 3A 7F
06/15/2026 10:12:31.254 PM Received
FF 03 6B 00 00 05 10 00 18 74
06/15/2026 10:12:31.254 PM Sending
FF 02 6B 05 11 3A 7E
06/15/2026 10:12:31.257 PM Received
FF 03 6B 00 00 05 11 00 19 74
06/15/2026 10:12:31.258 PM Sending
FF 02 6B 05 02 3A 6D
06/15/2026 10:12:31.265 PM Received
FF 03 6B 00 00 05 02 02 0A 76
06/15/2026 10:12:31.265 PM Sending
FF 02 6B 05 00 3A 6F
06/15/2026 10:12:31.273 PM Received
FF 03 6B 00 00 05 00 00 08 74
06/15/2026 10:12:31.274 PM Sending
FF 02 6B 05 01 3A 6E
06/15/2026 10:12:31.279 PM Received
FF 04 6B 00 00 05 01 01 00 2C 68
06/15/2026 10:12:31.279 PM Sending
FF 02 6B 05 12 3A 7D
06/15/2026 10:12:31.286 PM Received
FF 03 6B 00 00 05 12 00 1A 74
06/15/2026 10:12:31.286 PM Sending
FF 02 6B 05 16 3A 79
06/15/2026 10:12:31.290 PM Received
FF 02 6B 01 05 05 16 EE 60
06/15/2026 10:12:31.290 PM Sending
FF 01 62 00 BE BD
06/15/2026 10:12:31.293 PM Received
FF 03 62 00 00 00 0A 8C A1 2A
06/15/2026 10:12:31.293 PM Sending
FF 01 64 00 B8 BD
06/15/2026 10:12:31.296 PM Received
FF 03 64 00 00 00 0A 8C 86 B3
06/15/2026 10:12:31.297 PM Sending
FF 02 6A 01 04 2E 4A
06/15/2026 10:12:31.302 PM Received
FF 03 6A 00 00 01 04 00 3A 44
06/15/2026 10:12:31.302 PM Sending
06/15/2026 10:12:31.308 PM Received
06/15/2026 10:12:31.312 PM Sending
FF 04 06 00 01 C2 00 A4 60
06/15/2026 10:12:31.315 PM Received
FF 00 06 00 00 E4 06
06/15/2026 10:12:31.315 PM Sending
FF 01 61 05 BD B8
06/15/2026 10:12:31.319 PM Received
FF 03 61 00 00 05 01 00 61 DF
06/15/2026 10:12:31.319 PM Sending
FF 01 61 05 BD B8
06/15/2026 10:12:31.322 PM Received
06/15/2026 10:12:31.322 PM Sending
FF 01 61 05 BD B8
06/15/2026 10:12:31.326 PM Received
06/15/2026 10:12:31.326 PM Sending
FF 00 70 1D 7F
06/15/2026 10:12:31.329 PM Received
FF 02 70 00 00 00 05 3B 75
06/15/2026 10:12:31.330 PM Sending
FF 02 10 00 00 F0 93
06/15/2026 10:12:31.338 PM Received
FF 37 10 00 00 00 7F 01 02 41 49 02 02 00 30 04
02 96 19 08 02 00 01 10 0B 34 30 30 2D 30 30 36
37 2D 30 31 20 02 30 47 SERIAL NUMBER REDACTED FA 51
06/15/2026 10:12:31.338 PM Sending
FF 02 10 00 40 F0 D3
06/15/2026 10:12:31.342 PM Received
FF 16 10 00 00 00 40 SERIAL NUMBER REDACTED 19 6C
06/15/2026 10:12:31.364 PM Sending
FF 02 6A 01 03 2E 4D
06/15/2026 10:12:31.368 PM Received
FF 03 6A 00 00 01 03 00 3D 44
06/15/2026 10:12:31.368 PM Sending
FF 03 9A 01 03 00 AC 5D
06/15/2026 10:12:31.370 PM Received
FF 00 9A 00 00 A6 33
06/15/2026 10:12:31.370 PM Sending
FF 01 61 05 BD B8
06/15/2026 10:12:31.373 PM Received
06/15/2026 10:12:31.373 PM Sending
FF 01 61 05 BD B8
06/15/2026 10:12:31.378 PM Received
06/15/2026 10:12:44.163 PM Sending
FF 02 92 0A 64 4B 3D
06/15/2026 10:12:44.167 PM Received
06/15/2026 10:12:44.183 PM Sending
FF 02 92 0A 46 4B 1F
06/15/2026 10:12:44.185 PM Received
06/15/2026 10:12:44.194 PM Sending
FF 02 92 0A 1E 4B 47
06/15/2026 10:12:44.196 PM Received
06/15/2026 10:12:44.203 PM Sending
FF 02 92 09 D8 48 81
06/15/2026 10:12:44.206 PM Received
06/15/2026 10:12:44.213 PM Sending
FF 02 92 09 92 48 CB
06/15/2026 10:12:44.215 PM Received
06/15/2026 10:12:44.223 PM Sending
FF 02 92 09 06 48 5F
06/15/2026 10:12:44.225 PM Received
06/15/2026 10:12:44.234 PM Sending
FF 02 92 08 C0 49 99
06/15/2026 10:12:44.236 PM Received
06/15/2026 10:12:44.244 PM Sending
FF 02 92 08 66 49 3F
06/15/2026 10:12:44.246 PM Received
06/15/2026 10:12:44.252 PM Sending
FF 02 92 08 48 49 11
06/15/2026 10:12:44.255 PM Received
06/15/2026 10:12:44.263 PM Sending
FF 02 92 07 F8 46 A1
06/15/2026 10:12:44.265 PM Received
06/15/2026 10:12:44.283 PM Sending
FF 02 92 07 DA 46 83
06/15/2026 10:12:44.286 PM Received
06/15/2026 10:12:44.303 PM Sending
FF 02 92 07 B2 46 EB
06/15/2026 10:12:44.306 PM Received
06/15/2026 10:12:44.336 PM Sending
FF 02 92 07 94 46 CD
06/15/2026 10:12:44.338 PM Received
06/15/2026 10:12:44.375 PM Sending
FF 02 92 07 76 46 2F
06/15/2026 10:12:44.376 PM Received
06/15/2026 10:12:44.406 PM Sending
FF 02 92 07 4E 46 17
06/15/2026 10:12:44.408 PM Received
06/15/2026 10:12:44.425 PM Sending
FF 02 92 07 30 46 69
06/15/2026 10:12:44.427 PM Received
06/15/2026 10:12:44.445 PM Sending
FF 02 92 07 08 46 51
06/15/2026 10:12:44.447 PM Received
06/15/2026 10:12:44.464 PM Sending
FF 02 92 06 EA 47 B3
06/15/2026 10:12:44.467 PM Received
06/15/2026 10:12:44.485 PM Sending
FF 02 92 06 C2 47 9B
06/15/2026 10:12:44.487 PM Received
06/15/2026 10:12:44.495 PM Sending
FF 02 92 06 A4 47 FD
06/15/2026 10:12:44.498 PM Received
06/15/2026 10:12:44.504 PM Sending
FF 02 92 06 54 47 0D
06/15/2026 10:12:44.507 PM Received
06/15/2026 10:12:44.514 PM Sending
FF 02 92 06 40 47 19
06/15/2026 10:12:44.516 PM Received
06/15/2026 10:12:44.523 PM Sending
FF 02 92 06 18 47 41
06/15/2026 10:12:44.526 PM Received
06/15/2026 10:12:44.534 PM Sending
FF 02 92 05 D2 44 8B
06/15/2026 10:12:44.537 PM Received
06/15/2026 10:12:44.543 PM Sending
FF 02 92 05 AA 44 F3
06/15/2026 10:12:44.547 PM Received
06/15/2026 10:12:44.554 PM Sending
FF 02 92 05 82 44 DB
06/15/2026 10:12:44.556 PM Received
06/15/2026 10:12:44.576 PM Sending
FF 02 92 05 64 44 3D
06/15/2026 10:12:44.579 PM Received
06/15/2026 10:12:44.596 PM Sending
FF 02 92 05 3C 44 65
06/15/2026 10:12:44.598 PM Received
06/15/2026 10:12:44.715 PM Sending
FF 02 92 05 28 44 71
06/15/2026 10:12:44.719 PM Received
06/15/2026 10:12:44.775 PM Sending
FF 02 92 05 00 44 59
06/15/2026 10:12:44.778 PM Received
06/15/2026 10:12:44.816 PM Sending
FF 02 92 04 D8 45 81
06/15/2026 10:12:44.818 PM Received
06/15/2026 10:12:44.852 PM Sending
FF 02 92 04 BA 45 E3
06/15/2026 10:12:44.855 PM Received
06/15/2026 10:12:44.878 PM Sending
FF 02 92 04 92 45 CB
06/15/2026 10:12:44.881 PM Received
06/15/2026 10:12:44.897 PM Sending
FF 02 92 04 6A 45 33
06/15/2026 10:12:44.899 PM Received
06/15/2026 10:12:44.918 PM Sending
FF 02 92 04 4C 45 15
06/15/2026 10:12:44.922 PM Received
06/15/2026 10:12:44.936 PM Sending
FF 02 92 04 2E 45 77
06/15/2026 10:12:44.938 PM Received
06/15/2026 10:12:44.965 PM Sending
FF 02 92 04 10 45 49
06/15/2026 10:12:44.968 PM Received
06/15/2026 10:12:44.986 PM Sending
FF 02 92 03 E8 42 B1
06/15/2026 10:12:44.988 PM Received
06/15/2026 10:12:45.027 PM Sending
FF 02 92 03 C0 42 99
06/15/2026 10:12:45.030 PM Received
06/15/2026 10:12:45.065 PM Sending
FF 02 92 03 A2 42 FB
06/15/2026 10:12:45.069 PM Received
06/15/2026 10:12:45.116 PM Sending
FF 02 92 03 7A 42 23
06/15/2026 10:12:45.120 PM Received
06/15/2026 10:12:45.158 PM Sending
FF 02 92 03 66 42 3F
06/15/2026 10:12:45.159 PM Received
06/15/2026 10:12:45.218 PM Sending
FF 02 92 03 3E 42 67
06/15/2026 10:12:45.220 PM Received
06/15/2026 10:12:45.549 PM Sending
FF 02 92 03 16 42 4F
06/15/2026 10:12:45.553 PM Received
06/15/2026 10:12:45.591 PM Sending
FF 02 92 02 F8 43 A1
06/15/2026 10:12:45.593 PM Received
06/15/2026 10:12:45.648 PM Sending
FF 02 92 02 D0 43 89
06/15/2026 10:12:45.650 PM Received
06/15/2026 10:12:45.861 PM Sending
FF 02 92 02 B2 43 EB
06/15/2026 10:12:45.864 PM Received
06/15/2026 10:12:45.900 PM Sending
FF 02 92 02 8A 43 D3
06/15/2026 10:12:45.902 PM Received
06/15/2026 10:12:45.934 PM Sending
FF 02 92 02 6C 43 35
06/15/2026 10:12:45.936 PM Received
06/15/2026 10:12:45.961 PM Sending
FF 02 92 02 4E 43 17
06/15/2026 10:12:45.963 PM Received
06/15/2026 10:12:45.992 PM Sending
FF 02 92 02 26 43 7F
06/15/2026 10:12:45.994 PM Received
06/15/2026 10:12:46.031 PM Sending
FF 02 92 02 08 43 51
06/15/2026 10:12:46.034 PM Received
06/15/2026 10:12:46.072 PM Sending
FF 02 92 01 E0 40 B9
06/15/2026 10:12:46.074 PM Received
06/15/2026 10:12:46.101 PM Sending
FF 02 92 01 B8 40 E1
06/15/2026 10:12:46.104 PM Received
06/15/2026 10:12:46.121 PM Sending
FF 02 92 01 A4 40 FD
06/15/2026 10:12:46.124 PM Received
06/15/2026 10:12:46.151 PM Sending
FF 02 92 01 7C 40 25
06/15/2026 10:12:46.153 PM Received
06/15/2026 10:12:46.180 PM Sending
FF 02 92 01 5E 40 07
06/15/2026 10:12:46.182 PM Received
06/15/2026 10:12:46.210 PM Sending
FF 02 92 01 36 40 6F
06/15/2026 10:12:46.212 PM Received
06/15/2026 10:12:46.251 PM Sending
FF 02 92 01 0E 40 57
06/15/2026 10:12:46.253 PM Received
06/15/2026 10:12:46.310 PM Sending
FF 02 92 00 F0 41 A9
06/15/2026 10:12:46.314 PM Received
06/15/2026 10:12:47.357 PM Sending
FF 02 92 01 04 40 5D
06/15/2026 10:12:47.359 PM Received
06/15/2026 10:12:47.416 PM Sending
FF 02 92 01 2C 40 75
06/15/2026 10:12:47.419 PM Received
06/15/2026 10:12:47.476 PM Sending
FF 02 92 01 4A 40 13
06/15/2026 10:12:47.478 PM Received
06/15/2026 10:12:47.526 PM Sending
FF 02 92 01 72 40 2B
06/15/2026 10:12:47.530 PM Received
06/15/2026 10:12:48.900 PM Sending
FF 02 94 0A 64 2B FB
06/15/2026 10:12:48.903 PM Received
06/15/2026 10:12:48.942 PM Sending
FF 02 94 0A 46 2B D9
06/15/2026 10:12:48.945 PM Received
06/15/2026 10:12:48.993 PM Sending
FF 02 94 0A 1E 2B 81
06/15/2026 10:12:48.995 PM Received
06/15/2026 10:12:49.022 PM Sending
FF 02 94 09 F6 28 69
06/15/2026 10:12:49.024 PM Received
06/15/2026 10:12:49.031 PM Sending
FF 02 94 09 B0 28 2F
06/15/2026 10:12:49.033 PM Received
06/15/2026 10:12:49.040 PM Sending
FF 02 94 09 6A 28 F5
06/15/2026 10:12:49.042 PM Received
06/15/2026 10:12:49.050 PM Sending
FF 02 94 08 E8 29 77
06/15/2026 10:12:49.054 PM Received
06/15/2026 10:12:49.061 PM Sending
FF 02 94 08 5C 29 C3
06/15/2026 10:12:49.063 PM Received
06/15/2026 10:12:49.069 PM Sending
FF 02 94 07 B2 26 2D
06/15/2026 10:12:49.072 PM Received
06/15/2026 10:12:49.079 PM Sending
FF 02 94 06 C2 27 5D
06/15/2026 10:12:49.082 PM Received
06/15/2026 10:12:49.090 PM Sending
FF 02 94 05 BE 24 21
06/15/2026 10:12:49.092 PM Received
06/15/2026 10:12:49.099 PM Sending
FF 02 94 05 3C 24 A3
06/15/2026 10:12:49.102 PM Received
06/15/2026 10:12:49.109 PM Sending
FF 02 94 04 F6 25 69
06/15/2026 10:12:49.112 PM Received
06/15/2026 10:12:49.120 PM Sending
FF 02 94 04 6A 25 F5
06/15/2026 10:12:49.122 PM Received
06/15/2026 10:12:49.130 PM Sending
FF 02 94 03 E8 22 77
06/15/2026 10:12:49.133 PM Received
06/15/2026 10:12:49.140 PM Sending
FF 02 94 03 A2 22 3D
06/15/2026 10:12:49.143 PM Received
06/15/2026 10:12:49.151 PM Sending
FF 02 94 03 16 22 89
06/15/2026 10:12:49.154 PM Received
06/15/2026 10:12:49.160 PM Sending
FF 02 94 02 D0 23 4F
06/15/2026 10:12:49.163 PM Received
06/15/2026 10:12:49.170 PM Sending
FF 02 94 02 80 23 1F
06/15/2026 10:12:49.172 PM Received
06/15/2026 10:12:49.180 PM Sending
FF 02 94 02 58 23 C7
06/15/2026 10:12:49.182 PM Received
06/15/2026 10:12:49.192 PM Sending
FF 02 94 02 30 23 AF
06/15/2026 10:12:49.194 PM Received
06/15/2026 10:12:49.212 PM Sending
FF 02 94 02 12 23 8D
06/15/2026 10:12:49.215 PM Received
06/15/2026 10:12:49.221 PM Sending
FF 02 94 01 F4 20 6B
06/15/2026 10:12:49.223 PM Received
06/15/2026 10:12:49.243 PM Sending
FF 02 94 01 D6 20 49
06/15/2026 10:12:49.245 PM Received
06/15/2026 10:12:49.263 PM Sending
FF 02 94 01 AE 20 31
06/15/2026 10:12:49.265 PM Received
06/15/2026 10:12:49.290 PM Sending
FF 02 94 01 86 20 19
06/15/2026 10:12:49.293 PM Received
06/15/2026 10:12:49.685 PM Sending
FF 02 94 01 A4 20 3B
06/15/2026 10:12:49.688 PM Received
06/15/2026 10:12:50.396 PM Sending
06/15/2026 10:12:50.398 PM Received
06/15/2026 10:12:50.436 PM Sending
FF 02 94 01 68 20 F7
06/15/2026 10:12:50.438 PM Received
06/15/2026 10:13:03.723 PM Sending
FF 02 93 00 05 51 7D
06/15/2026 10:13:03.739 PM Received
FF 00 93 00 00 37 1A
06/15/2026 10:13:03.739 PM Sending
FF 03 91 02 01 01 42 C5
06/15/2026 10:13:03.743 PM Received
FF 00 91 00 00 17 58
06/15/2026 10:13:03.743 PM Sending
FF 08 22 88 10 00 13 02 EE 00 57 4C 28
06/15/2026 10:13:04.494 PM Received
FF 00 22 04 00 84 E0
06/15/2026 10:13:09.816 PM Sending
FF 03 9A 01 0C 01 A3 5C
06/15/2026 10:13:09.819 PM Received
06/15/2026 10:13:09.819 PM Sending
FF 01 62 00 BE BD
06/15/2026 10:13:09.822 PM Received
FF 03 62 00 00 00 01 72 AA D4
06/15/2026 10:13:09.822 PM Sending
FF 01 64 00 B8 BD
06/15/2026 10:13:09.824 PM Received
FF 03 64 00 00 00 01 68 8D 57
06/15/2026 10:13:09.824 PM Sending
FF 03 9B 05 02 02 DE EA
06/15/2026 10:13:09.830 PM Received
FF 00 9B 00 00 B6 12
06/15/2026 10:13:09.830 PM Sending
FF 03 9B 05 12 00 CE E8
06/15/2026 10:13:09.833 PM Received
06/15/2026 10:13:09.833 PM Sending
FF 03 9B 05 16 00 CA E8
06/15/2026 10:13:09.835 PM Received
FF 00 9B 01 05 B7 17
06/15/2026 10:13:09.835 PM Sending
FF 03 9B 05 10 00 CC E8
06/15/2026 10:13:09.851 PM Received
06/15/2026 10:13:09.851 PM Sending
FF 03 9B 05 11 00 CD E8
06/15/2026 10:13:09.857 PM Received
06/15/2026 10:13:09.857 PM Sending
06/15/2026 10:13:09.863 PM Received
06/15/2026 10:13:09.863 PM Sending
06/15/2026 10:13:09.865 PM Received
06/15/2026 10:13:09.865 PM Sending
06/15/2026 10:13:09.868 PM Received
06/15/2026 10:13:09.868 PM Sending
06/15/2026 10:13:09.884 PM Received
06/15/2026 10:13:09.885 PM Sending
06/15/2026 10:13:09.891 PM Received
I apologize for breaking this post up into multiple messages. I signed up for the forum, then composed the post, and after clicking “Create Topic” a popup said that new users can’t post more than one link or embedded graphic, so I had to split the post up into pieces. Then it said I was posting too fast and had to wait
Thanks for any help you can provide. Without access to the Read function on the Tag Results tab, I don’t see a way to play Radio Horsehoes as shown in this fun video
PS: I threw AI at this and it thinks that the following commands show URA trying to iterate through multiple antenna ports whereas the board only has one antenna connected/active.
Sending FF 02 6B 05 10 … Sending FF 02 6B 05 11 … Sending FF 02 6B 05 02 … Sending FF 02 6B 05 00 … Sending FF 02 6B 05 01 … Sending FF 02 6B 05 12 … Sending FF 02 6B 05 16 …
AI also says:
These look exactly like: - **multi-port / multi-antenna probing logic**
That logic is valid for:
- M6e
- Micro
NOT valid for Nano
I am not sure if this is the problem (it does seem to jibe with the example of this error I found in the PDF above). If so, how can I fix it? I assume this is something URA is doing that I can’t control (I think I have the antenna parameter set correctly? There’s only one and it is ‘01’). Do I need an older version of URA?
The URA works, no need for another one.
In read/write option, select:
antenna dynamic
do NOT select antenna detection and NOT select antenna multiplexing
select 01
select Gen2
do NOT select any of the GPIO’s
do NOT select filter
Just in case you wonder the debug file:
result.txt (76.9 KB)
Your firmware on the M6E is old (1.07). There is a 1.9 release available from Jadak/thingmagic that you can load with the URA menu (bottom right hand side)
Hello @paulvha - Thank you for reading and responding to my post!
I double checked these parameters were set the way you mentioned. These are the default settings (except that (antenna) 01 has to be checked each time I connect to the reader). However, I still get the same error:
I tried with “Read Continuously” enabled, and get a slightly different error:
Is there anything else I can try?
Thank you again
I think you have to upgrade the firmware. Never heard/seen license update.
Maybe if you look on the Jadak website they still have your 1.07 version, but the 1.19 works on an my M6E.
In the result.txt file I shared earlier the Me6 is not able to handle a GEN2 request. The might be your error. THe Jadak/Mercuri API is using that, the Sparkfun library is NOT sending that command.
********************************* SENDING DATA *********************************
ff 02 6b 05 16 3a 79
Sending request to get protocol parameters (0x6b): TMR_SR_OPCODE_GET_PROTOCOL_PARAM
Protocol: (5) PROTOCOL_GEN2
Parameter action: (0x16) TMR_SR_GEN2_INITIAL_Q
******************************** RECEIVED DATA *********************************
ff 02 6b 01 05 05 16 ee 60
ERROR: status returned 0x105 TMR_ERROR_MSG_INVALID_PARAMETER_VALUE.
Details : ff 02 6b 01 05 05 16 ee 60
I suspect that is you error.
