Magnetic imager silk screen error
I bought a magnetic imager tile 8x8 a couple of months ago and finally got around to hooking it up to a teensy 4.0. When I first wired it up I used the silk screen labels on the side with the pins. It was not properly advancing through the tiles. Finally I noticed that on the opposite side–the one with the hall effect sensors-- SCK and CLK labels are interchanged. The ones on the hall effect side work.
Thanks for pointing this out; we’ll get it fixed!
Hi guys – just to let you know, this still hasn’t been fixed. (I know because I thought the first board I bought was busted after trying it with multiple controllers, and ordered another one for rush delivery for a project. Only after I got the same null response from the second board did I spot the silkscreen didn’t match from one side to another! ) I figure there just hasn’t been another run of the board, but can I suggest at least a boxed warning note should placed in the hardware hookup tutorial?
You are correct about it being the same production batch :slight_smile:
Good idea, I’ll ask to get that added ASAP
