"make: rm: command not found" error tutorial
I am working my way through James Lynch’s ARM on eclipse tutorial. (It is excellent by the way.)
For some reason, the makefile processing gives an error:
“make: rm: command not found.”
I’ve dug a little deeper and it seems that is I remove the leading “-” in front of “rm” in the clean: section the project will build.
Does not work…
clean:
-rm crt.lst main.lst crt.o main.o main.out main.hex main.map main.dmp
Works…
clean:
Is there a typo in the tutorial or is there a problem with my cygwin setup?
I reinstalled cygwin and now its working with the “-rm”… strange.
