Hello, I have tried to work with a SparkFun Pulse Oximeter and Heart Rate Sensor - MAX30101 & MAX32664 (Qwiic), but none of the examples that come in the library can be executed, I already checked that the connections are adequate but this error appears: MAX30105 was not found. Please check wiring/power.
The 30105 is a separate sensor/library; use this one https://learn.sparkfun.com/tutorials/sp … no-library
And how can i use the green led of the MAX30101 with that library?
It looks like our examples only directly call them in SENSOR_DATA but aren’t referenced after - there’s a github issue for this here https://github.com/sparkfun/SparkFun_Bi … /issues/18 that you could add a comment to to ‘bump’ it
