We are currently trying to measure pH levels on the (wet) surface of metals as part of a study about corrosion. The surface may have a non-conductive protective layer.
is it feasible to measure pH on a planar surface (dry or wet)? Which kind of sensor probe can be used for this task?
which order of magnitude will be the measure? (precision of the sensor)
Any advice would be greatly appreciated!
