I want to use the Micro RGB Matrix tile in a project but not able to figure out the mating connector type for the data/power connectors on the back of this board:
https://www.sparkfun.com/products/15876
Appreciate any help!
Vipul
Vipul
That’s a good question and sadly I don’t have an answer for you but I think I know where you might be able to get help.
Check the link below, I think they may have the answer for you! ![]()
Thanks for the suggestion!
Here is the information I received from Gumstix, in case someone else finds it useful:
For the Micro RGB Matrix Tile:
Power: Molex Header, 5019400407
Data: Molex header, 5044490207
For the WiFi RGB LED Matrix:
Uses a USB Type C for power delivery
Power out: Molex Header, 5019400407
Awesome!
Glad they were able to help and thanks for posting the information you received, I’m sure it will be helpful to others. ![]()
