MicroMod projects in KiCad
Is there anywhere I can find a KiCad project for a micromod function board? It would save a bunch of time with the connector footprint and board edge-cuts etc if there was one that was already available. I want to make a second function board for a double carrier board project. (I already am using a processor and single function board).
Depending on how extensive the function board gets, I might go the other way and make a carrier board with a processor and function board on it, so Kicad Footprints/symbols for the connectors and stand-offs that I could use on a carrier would also be handy.
thx
Doug
You can import one of the existing boards into Kicad and start from there.
Yes. I just imported one and the KiCad import capability is a lot better than the last time I used it.
Worked quite well.
