MicroSD footprint in library
I laid out a PCB with the MICROSD-SKT footprint in the sparkfun library. When I received the PCB I found that the footprint does not match the microSD sockets I received from Sparkfun. Is this footprint for another microSD socket? If so, what is it and where can I find them?
Stan
4UConn (The supplier I suspect SFE uses) discontinued the old MicroSD socket and replaced it with the one that can now be seen here:
http://www.sparkfun.com/commerce/produc … cts_id=127
This update was not included in the January 8th 2009 release of the Eagle library, but I see a March 30th 2009 release has appeared. This should fix the issue.
As far as the old sockets, you are probably out of luck. I have a couple here but that’s only useful to you if your in Australia.
Unfortunately I’ve already completed the PCB. I would like to avoid laying out another board.
I’m in the USA.
Thank you for the information.
Stan
