MiniMod programming strings (inadvertently) sent
I literally have no idea how this is possible, but it appears as though I have sent some mode programming strings to the minimod; currently it is outputting only $GPGGA - nothing more.
I am using an Arduino Nano with 0012.
I have been experimenting with code I have found online, and I recall that one block had programming functions (to limit which NMEA strings were output), and I may have run that function, but I definitely declared pin 2 (software serial) as an input, so I cannot see how, even if I sent the codes by mistake, how the arduino would have allowed it.
In any case, I would like to know how to reprogram this thing to get all of the strings back again.
I can’t seem to find documentation regarding these modes on the MiniMod.
I found [this on the micro modular site.
Hope this helps!
gm](http://www.micro-modular.com/docs/AddlRsrc/Orion_UM_080614.pdf)
