Starting GPS MiniMod
Hello everyone
I am a beginner on GPS modules, and I ordered this one for a final project for my college.
I connected the module with VCC and ground, and sent the signal (TX pin) to the Osciloscope. As a result I saw what i think is a PWM of sorts.
What am wondering is, if i can read this output and process the data with a HCS08 Freescale microcontroller? Or is there a way to read it via UART without an Andrino interface?
I cant wait for the Andrino interface due to time limitations, but can I read it via UART and process it with a software application of my own that supports NMEA data format?
Thanks in advance for any prompt responses
Yup, you can. It should be standard uart serial communication. Just make sure you are communicating at the proper voltage!
