Hi, I just purchased a Monster Moto Shield unit (knowing they’re retired, which is ok). The first time I connected my power supply to the input pins + and - at the bottom, the input current immediately climbed beyond 15 A so I immediately disconnected power to prevent possible damage. This was with no load connected. Now I am confused at how to proceed. Any ideas?
It sounds like there is a short; share a photo of the soldering
Resistance over the input terminals is 600 Ohm
Did you inherit this used or something? It looks like it has been soldered to before (orange area)
I do see what might be some problem areas…namely the purples spots appear to be corroded
