I am new to mp3 and audio stuff in embedded systems.
Which one of the 3 models is best for mp3 player project LPC-2378STK, SAM7-EX256 or STR-E912 ?
Do they need extra hardware for this project like codecs ??!
thanks
thanks
I’d choose one for which you can get the software, unless you want to write it from scratch. You will need a DAC, or a codec, if the board you use hasn’t got one.
Leon
hi,leon_heller:
I’d choose one for which you can get the software, unless you want to write it from scratch. You will need a DAC, or a codec, if the board you use hasn’t got one.Leon
but the board is fitted with headphone jack. Is it connected to any DAC? if yes then i dont need any extra hardware.,isnt it?
what are the minmum specs for a DAC to get acceptable sound quality?
thanks
Do all the boards have that jack?
I think that 24-bit DACs are usually used, like those made by Cirrus. You need a proper audio device, anyway.
You still need a board for which you can easily get the software.
Leon
leon_heller:
Do all the boards have that jack?I think that 24-bit DACs are usually used, like those made by Cirrus. You need a proper audio device, anyway.
Leon
So which one has better support for audio application and generally?
i found that they offer this example “HID Audio device demo” is that enough to start?
thanks
I don’t think that HID is relevant, it refers to a USB device type.
I don’t know anything about those boards, I’ve only used the Embedded Artists ones.
Leon
