I received a new MP3 Trigger board and loaded up and SD card to try it out. It will play the first file on the card, but when using the on board navigation either forward or backward the status light turns green but I get nothing. Then seems like its frozen unless I restart the board?
All files are numbered sequentially using the 0XX*.mp3 convention.
Hello, what about the status LED? Is that powering up with 3 short blinks? The documentations of this board say that you can go to the previous and next tracks by using the serial control protocol also. Have you given that a try? Was there any success? Thank you.
