(Basically, I would like to modify an old lan telephone and play a sound whenever someone pick up the phone. So my idea is to put a photo resistor underneath the handset.)
I guess it is possible but I can’t find the answer online.
https://www.sparkfun.com/products/18448 is probably what you’re after Be sure to follow the hookup guide on the documents tab, and then just implement the sensor into your phone
@Brow I had definitely thought of using the the hang up switch and I will work on it but I am not sure yet if every phone I will modify will have this switch.
@TS-Russel, I’ll have a look on this although it seems a bit complicated for me. For instance, I have no clue how to set a define threshold above which a signal is sent from the sensor… https://learn.sparkfun.com/tutorials/qw … ample-code
