hi.
THIS little sketch won’t fit on my attiny85.
i get this error:
Build options changed, rebuilding all c:/program files (x86)/arduino/hardware/tools/avr/bin/…/lib/gcc/avr/4.8.1/…/…/…/…/avr/bin/ld.exe: C:\Users\donai\AppData\Local\Temp\build1801039637628455978.tmp/Blink_office_temp.cpp.elf section .text’ will not fit in regiontext’ c:/program files (x86)/arduino/hardware/tools/avr/bin/…/lib/gcc/avr/4.8.1/…/…/…/…/avr/bin/ld.exe: region `text’ overflowed by 418 bytes collect2.exe: error: ld returned 1 exit status Error compiling.
… and I think that means there’s not enough room.
From googling I believe it’s to do with the libraries taking up all the space and I am not duino literate enough to understand the discussion people have had about similar errors.
Does anyone have a fix or am I stuffed?
Basically, my [attiny85 is one of the digispark ones already mounted on a board and USB. if I can get it to work it will have one addressable LED sitting on top of it with a [DS18b20 attached to the side and will sit in my workstation’s USB in the office changing colour as the temperature fluctuates wildly during the day.
i never notice the change in temperature at work but everyone else does so it will give them something visible to moan about ![]()
thanks, don](http://www.componentschip.com/details/Maxim-Integrated/DS18B20.html)](http://www.componentschip.com/details/Atmel/ATTINY85.html)
