Hi We are using Myoware Muscle sensor and are gettign consistent data on sensors on the left and right biceps or triceps. However the amplitude or the measure of activity on the right arm sensor is consistently much lower than that on the left arm.
We are performing the same activity on both arms and have sensors attached at the exact same location on both arms. Both sensors are reading activity - the left hand sensor is reading a clear and distinct movement while the right hand sensor is reading a much lower signal. I have checked the gain on both sensors and they are almost identical. I have uploaded the screen shots from the serial output during the experiment. We are on a time sensitive project and any help is much appreciated.
I would suggest swapping sides and if you see the same thing happening, you might want to adjust the gain BARELY…they are very sensitive, I would adjust it live while in-place and with the 2nd sensor to compare to
Thank you! I assume I am increasing the gain on the right hand side ? We will try that and report back.
Yes, clockwise increases gain ![]()
