Need Help Identifying a Part
Does anyone know what these are called or where I can buy them? These are the non threaded 90 degree kind so that I can mount a PCB at a right angle.
https://www.dropbox.com/s/y3u3po09zpo4g … 3.jpg?dl=0
https://www.dropbox.com/s/tuk6h8el65nzp … 6.jpg?dl=0
http://cdn.macpartsonline.com/catalog/p … 2-5979.jpg
Don’t think I’ve ever seen those before. Digikey has these [brackets but they need screws on each end. I have used the threaded ones before. Do these snap into a hole or do they have to be soldered?
Try Keystone Electronics. They have tons of mounting hardware.](633 Keystone Electronics | Hardware, Fasteners, Accessories | DigiKey)
Spent the last 30 min using my Google-fu to see if I could find that bracket. Sadly, I was unsuccessful. These are the only things I could find, they are just too big.
http://www.rapidonline.com/electrical-p … ra-43-0786
http://cesyg.synth.net/page/products/ac … t-bracket/
I would try to ask this question on several different PCB forums and see if you can get it answered. I am also interested in these for my boards…
What about something like
http://www.digikey.com/product-detail/e … -ND/151547
Keystone has a bunch listed on Digikey under http://www.digikey.com/product-search/e … onnectors/
/mike
The last link n1ist posted is your best bet I think. Under filters, put in Solder and right angle…
Thanks for the help guys, I guess I’ll have to order a threaded one and see what I can do about it.
You can also search the Richco catalogue as I know they do a RA board mount connector in nylon for this sort of mounting, I have used them for a similar board.
Here is an RS example.
http://uk.rs-online.com/web/p/pcb-mount … s/3035330/
