Hi, I am new here and I hope I am posting this in the correct forum heading for best result.
Gauges and lights stopped working on my sisters instrument cluster. I pulled it and replaced the bulbs only to find that it would only work if I twisted Left corner top to me and Right corner top away.
I searched the board for broken joints, cracks, anything that would interrupt the circuit but was unable to see anything so I elevated it on a baking sheet and baked it in the oven @ 250 for 30 minutes. That worked for about a week ![]()
My second attempt was not as easy. I use no-clean flux on all the solder and used my hot air rework station @ 370 to carefully reflow the solder. That lasted about 3 months. There has to be damage to the board it’s self.
Bought another cluster from eBay and pulled the board, now I need to get the odometer right.
2 things.
What more could I have done to the original board?
Which IC would you believe holds the odometer memory?
This link takes you to google photo but does not open a new window, could not figure out the correct code for this site for onclick=window.open. If you use it I Right click open new tab.
https://photos.app.goo.gl/jn4KG5XwSNjGSjP8A
Drag and drop photo, Personally think the IC I am looking for is #1. Thank you for your help.
