I really hope someone cold help or point me in a good direction where I can help myself.
I am new to Arduino but not to coding so I understand mostly how to communicate with the boards.
Here is my issue. I have put together the M8U dead reckoning example exactly as described in “SparkFun GPS Dead Reckoning NEO-M8U Hookup Guide”. I ordered the same parts as well. I needed to change out the N.FL cable for SMA Female though.
I went through the process of Calibration which went OK. (Done in Car)
Then I could not get an NMEA sentence after running Basic NMEA Read Sketch. MY GPS was in open sky. After a bit of tinkering I eventually got the NMEA sentences out of the serial and my PC was able to log my movement. (Done at desktop)
When I moved the device back to the car I figured I should calibrate again. Then load the Basic NMEA Read sketch again.
At this point I got nothing. The GPS does not get a fix on any Satellites. I have been at this for 3 days now and have tried everything I can think of.
Luckily I have access to a large supply of GPS antenna so can rule out the antenna as an issue.
I have extensive knowledge of working with GPS’s so know for a fact I have full view of the SKY.
It worked once so it should work again with the same config.
Here is where I need help.
Is there a specific process I need to go through in order to get NMEA sentences or even NMEA parsing to work.
Does the M8U need to be calibrated in order to get a GPS fix.
Is there a way to reset my Breakout Board and Redboard QWIIC back to factory default.
Any help will be very much appreciated.
